Go Back   Mopar Forums > CLASSIC DODGE, CHRYSLER, & PLYMOUTH MODELS > B-Body
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 05-11-2008, 02:41 PM   #1 (permalink)
mopars&vampires
Junior Member
Fuel pump frustration in a 69 charger-
Hello I am new here-
So today I put myself in a good bind. I finally got my ’69 charger back on the road recently after an engine rebuild (383), a painless wire harness install, and a bunch of front suspension work. Doing pretty good, but I notice that I am still drooling a little oil when I get going. So I tracked the source to the fuel pump. Took it off and found a goobered gasket probably done by my old roommate who is a GM guy who helped my with my rebuild. Bought the $2 gasket and figured I would be done soon. Well, I apparently don’t have the sequence right. I noticed that to get the pump back on and have the bolts square, I would need to remove the fuel pump pushrod. Fine, but then how do I get it back in? Maybe get one bolt in, replace the pushrod, then get the second one in? That seemed to work but I had not put the gasket in place to prevent damaging it. Long story short, the second time I only managed to fubar my threads and get nowhere but close. So I need to get the threads fixed (know any one in colorado who does a good job?) But then how do I prevent this from happening again, am I missing something in the sequence? Someone have a tutorial? I have the shop manual and it didn’t have much to offer for the installation. I am pretty mechanical and have worked on many a cars and done almost all the work on this car myself. This is really the first major f-up I have done of this caliber. The fuel pump is an aftermarket carter, so that might be part of the issue. Any advice welcome. Thanks
mopars&vampires is offline   Reply With Quote
Old 05-12-2008, 09:07 AM   #2 (permalink)
440roadrunner
Senior Member
I would check the part number of the pump to be sure you have a correct pump. All 383 and other related BB engines "can" use the same pump, so if your pump has the right hose connections, and is supposed to fit a 361-383-440, etc, it will fit.
Have you bumped the engine over to get the pushrod "up" as far as it will go? I don't remember any issues with these, but it's been a long time. My recollection is, I put my finger or a scrap of plastic in under the pump rod, and either "bumped" the engine or turned the front nut with a wrench until the rod was "up"
Glue the gasket to the pump, ease the arm under the pump rod and push gently until the pump seats. It's easy to pull the alternator out of the way, so you should be able to see what you're doing.
440roadrunner is offline   Reply With Quote
Old 05-12-2008, 04:34 PM   #3 (permalink)
mopars&vampires
Junior Member
440roadrunner- I think you are 100% correct. I am verifying that I have all right components and I just spoke with another mopar guy who stated that I needed to make sure the pushrod was up more by turning the engine. Too bad I didnt realize I was tearing into my threads until it was too late. Thanks again though
Old 05-18-2008, 07:27 PM   #4 (permalink)
mopars&vampires
Junior Member
Ok chased the threads and figured out that I was not pushing the push rod far enough. So, pump installed and no leaks. BUT- suddenly oil is nearly gushing out of my dipstick when I drive (at the top). Its all fine at idle, but when I drive it gushes out the top. I figure that the seal just isnt doing its job since the Auto meter guage says oil pressure is normal and everything seems normal. Is there anything else I should be concerned about? Thanks for further thoughts
Old 05-26-2008, 12:07 AM   #5 (permalink)
CoryOriho
RaptorMountainKing
Send a message via MSN to CoryOriho
Quote:
maybe there is a breather valve on the block? or the pressure isn't being sent somewhere, a clog...if the breather valve doesn't work it will go anywhere it can and sometimes even fuck up more stuff then you will ever want, its almost like having standing water in your pistons
__________________
1975 Ford -f250
Yamaha Raptor 660r
Polaris RMK 700
1970ish RoadRunner? xD
CoryOriho is offline   Reply With Quote
Old 05-30-2008, 06:37 AM   #6 (permalink)
mopars&vampires
Junior Member
Yeah, I figured it out and its a little embarrassing. I was looking thru the shop manual and came upon a diagram of the PCV system and suddenly realized in our haste I had never installed a breather at all. Things had been OK because the fuel pump never sealed and air could get in there. When I sealed things it became a problem. So, one $7 twist on-breather later, I think things are good again. Thanks for the help though guys. CoryOriho- You would have been the solution if I hadnt stumbled onto it about an hour before I read your post
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
fuel starvation Rulito A-Body 7 04-28-2008 11:29 PM
Manual foot pump Washer Jar? Stephen G. Rao E-Body 0 02-26-2008 06:00 PM
Fuel Pressure Regulator 96 Cherokee mfinkler Do-It-yourself Section 0 11-14-2007 05:21 AM
440 fuel pump woes??? rapidride2 General Technical Questions 0 03-20-2007 05:58 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
