Powerwagon headers
I have a 1970 power wagon that I swapped a 440 into and I was wondering if anyone knows where to get headers for it? The problem I am having is the steering column runs right next to the exhaust and I cant find any skinny enough. Any help would be appreciated.
Check with Bouchillon in North Charleston SC or maybe Mancini. Just google for them.
Joe |
headers
5809HKR
http://www.holley.com/data/products/...all5809HKR.jpg Super Comp. Header 74–78 Dodge Ramcharger/W–100/W–200, 74–78 Plymouth Trailduster: 400–440, 67–71 W–100/W–200: 383, Full length Tube Size 1.75" x 29", Collector Size 2.5", Collector Length 8", Port Shape: Same As Port, Black High Temp Paint Contact Hooker headers or Summit racing 1-800-230-3030 and talk with thier tech guys, They may have what you need and are good to deal with. http://www.summitracing.com/ Another suggestion is to get the 383 headers and have a muffler shop add to the tubes to clear the steering. |
Isn't the 72 and up chassis way diff than the 71 and down? ... I don't think the later headers will fit.
I believe they were different, Hooker listed all them together in thier ad, I believe they have seperate parts numbers for the 67–71 W–100/W–200: 383. Summit should be able to find them.
1972-93 was the Lifestyle pickups and were much different from the 61-71 Sweptline era pickups. Engine blocks were the same (Poly notwithstanding) but the engine compartment, power steering location etc is completely different on the Lifestyles.
On my 68, W200 383 Sweptline, I got the Hookers and only had to make slight adjustments for them to fit. On a D100/200 no mods would have been needed. My 69 W200 (avatar) has an old Poly in it with DTA headers and they are sweet!!! |
Originally Posted by somkeone
(Post 2091)
this page and website has what you need. look at the bottom of the page for the part numbers. then look up the part numbers at summit racing. http://www.sweptline.com/tech/engine3.html |
:mad:just another one-post wonder guys
(Post 2091)
Start by looking at the damper to see if it's internally balanced. Take a look at the flat pad in front of the valley pan also for stamping. You can find information on IDing the block online. Google is your friend.
This thread is 13 years old so I'd be willing to bet the issue was resolved long ago....
