NHRA Fram Nationals Sonoma
Fri, 29 Jul 2011, 07:10 PM
http://www.dragracecentral.com/image...00_leftdot.gif Pro Stock Qualifying Notes, Session #1 By Rick Green http://www.dragracecentral.com/image...00_leftdot.gif http://www.dragracecentral.com/images/small_print.gif SONOMA, Calif. - Notes from round 1 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 24th annual FRAM-Autolite NHRA Nationals listing lane, driver name, elapsed time, top speed, and position in order following run: Left Lane: Gordie Rivera Runs 6.806/204.79, Now #2 Right Lane: Warren Johnson Runs 6.764/207.34, Now #1 Weather conditions: air temperature 79 degrees, relative humidity 49 percent, barometer 29.86 inches, adjusted altitude 2,029 feet, track temperature 121 degrees. Gordie Rivera's incremental times: 60ft-1.024 sec., 330ft-2.870, 660ft-4.393/162.20 mph, 1,000ft-5.703. Warren Johnson's incremental times: 60ft-1.028 sec., 330ft-2.861, 660ft-4.377/163.14 mph, 1,000ft-5.674. Left Lane: Kurt Johnson Runs 15.824/51.26, Now #4 Right Lane: V. Gaines Runs 6.621/209.46, Now #1 Johnson with problems and pushes in the clutch early and coast on through the 1320. gaines with a real nice pass to start the weekend. V. Gaines' incremental times: 60ft-0.999 sec., 330ft-2.784, 660ft-4.266/166.31 mph, 1,000ft-5.544. Left Lane: Ronnie Humphrey Runs 6.660/209.56, Now #3 Right Lane: Larry Morgan Runs 6.657/207.88, Now #2 A couple good passes...Humphrey with the fastest pass of the round. Ronnie Humphrey's incremental times: 60ft-1.040 sec., 330ft-2.829, 660ft-4.309/166.44 mph, 1,000ft-5.585. Larry Morgan's incremental times: 60ft-1.005 sec., 330ft-2.797, 660ft-4.285/165.07 mph, 1,000ft-5.571. Left Lane: Ron Krisher No Time, Now #8 Right Lane: Shane Gray Runs 6.702/208.10, Now #4 Krisher with problems and is pushed back before he stages. Shane Gray's incremental times: 60ft-1.019 sec., 330ft-2.833, 660ft-4.329/164.67 mph, 1,000ft-5.617. Left Lane: Rodger Brogdon Runs 8.210/117.48, Now #8 Right Lane: Erica Enders Runs 6.617/208.75, Now #1 Brogdon with problems and he pushes in the clutch early. Enders launched hard and keep it hooked up to go to the number one spot. Erica Enders' incremental times: 60ft-0.990 sec., 330ft-2.772, 660ft-4.256/165.74 mph, 1,000ft-5.536. Left Lane: Allen Johnson Runs 6.576/210.31, Now #1 Right Lane: Greg Stanfield Runs 6.839/207.27, Now #9 Johnson with the quickest 60-foot of the session and a great pass to go to the number one spot...Allen Johnson's incremental times: 60ft-0.981 sec., 330ft-2.750, 660ft-4.227/166.50 mph, 1,000ft-5.501. Stanfield with a good pass. Greg Stanfield's incremental times: 60ft-1.096 sec., 330ft-2.958, 660ft-4.460/164.15 mph, 1,000ft-5.751. Left Lane: Vincent Nobile Runs 6.624/209.65, Now #4 Right Lane: Greg Anderson Runs 10.401/84.87, Now #12 Nobile with a real nice pass to go to the number four spot. Vincent Nobile's incremental times: 60ft-0.997 sec., 330ft-2.782, 660ft-4.267/165.72 mph, 1,000ft-5.547. Anderson with problems and he pushes in the clutch. Left Lane: Mike Edwards Runs 9.714/92.09, Now #12 Right Lane: Jason Line Runs 16.687/46.99, Now #15 Line made a quick move toward the wall and clicked it off. Edwards with problems and he pushes in the clutch early. Timing data courtesy of CompuLink http://www.dragracecentral.com/image...t_endstory.gif From DragRaceCentral.com http://www.dragracecentral.com/image...00_leftdot.gif |
Round 2 Qualifying
Fri, 29 Jul 2011, 10:30 PM
http://www.dragracecentral.com/image...00_leftdot.gif Pro Stock Qualifying Notes, Session #2 By Rick Green http://www.dragracecentral.com/image...00_leftdot.gif http://www.dragracecentral.com/images/small_print.gif SONOMA, Calif. - Notes from round 2 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 24th annual FRAM-Autolite NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run: Left Lane: Jason Line Runs 14.190/57.34, Now #15; Best prior run: 16.687/46.99, Was #15 Right Lane: Ron Krisher Runs 6.608/209.62, Now #2; No Prior Run Line with problems again and he pushes in the clutch...Krisher launched hard and made a great pass to go to then number two spot. Ron Krisher's incremental times: 60ft-0.993 sec., 330ft-2.776, 660ft-4.256/166.11 mph, 1,000ft-5.532. Left Lane: Greg Anderson Runs 6.592/209.69, Now #2; Best prior run: 10.401/84.87, Was #14 Right Lane: Kurt Johnson Runs 6.607/209.39, Now #3; Best prior run: 15.824/51.26, Was #16 This was a great drag race as Anderson goes to the number two spot and Johnson the number three spot. Greg Anderson's incremental times: 60ft-0.980 sec., 330ft-2.764, 660ft-4.242/166.48 mph, 1,000ft-5.517. Kurt Johnson's incremental times: 60ft-0.987 sec., 330ft-2.770, 660ft-4.251/165.99 mph, 1,000ft-5.530. Left Lane: Greg Stanfield Runs 6.593/208.39, Now #4; Best prior run: 6.839/207.27, Was #13 Right Lane: Mike Edwards Runs 6.587/209.56, Now #2; Best prior run: 9.714/92.09, Was #15 Edwards with a great short time and goes to the number two spot...Mike Edwards' incremental times: 60ft-0.975 sec., 330ft-2.757, 660ft-4.236/166.35 mph, 1,000ft-5.512. Stanfield was right there with him to go to the number tree spot. Greg Stanfield's incremental times: 60ft-0.984 sec., 330ft-2.755, 660ft-4.235/166.19 mph, 1,000ft-5.513. Left Lane: Warren Johnson Runs 6.609/208.46, Now #8; Best prior run: 6.764/207.34, Was #13 Right Lane: Rodger Brogdon Runs 6.595/209.14, Now #5; Best prior run: 8.210/117.48, Was #15 A couple good passes here as Brogdon gets into the top half of the show for now. Rodger Brogdon's incremental times: 60ft-0.979 sec., 330ft-2.753, 660ft-4.239/165.90 mph, 1,000ft-5.517. WJ with a nice pass to go to the number eight spot. Warren Johnson's incremental times: 60ft-0.985 sec., 330ft-2.764, 660ft-4.249/165.88 mph, 1,000ft-5.529. Left Lane: Shane Gray Runs 6.619/208.91, Now #10; Best prior run: 6.702/208.10, Was #14 Right Lane: Gordie Rivera Runs 17.369/43.06, Now #15; Best prior run: 6.806/204.79, Was #15 Rivera with violent tire shake as soon as he let the clutch out and then pushes the clutch back in and coast down the 1320. Gray makes a move in the right direction to get in the show. Shane Gray's incremental times: 60ft-0.998 sec., 330ft-2.786, 660ft-4.261/165.62 mph, 1,000ft-5.540. Left Lane: Larry Morgan Runs 6.576/209.36, Now #2; Best prior run: 6.657/207.88, Was #13 Right Lane: Ronnie Humphrey Runs 6.577/209.65, Now #3; Best prior run: 6.660/209.56, Was #14 This was a great side-by-side drag race as these two go to the number two and three spots. Morgan ties Allen Johnson for the quickest E.T., but gave up the spot based on the speed. Humphrey with a great pass. Larry Morgan's incremental times: 60ft-0.986 sec., 330ft-2.754, 660ft-4.228/166.85 mph, 1,000ft-5.501. Ronnie Humphrey's incremental times: 60ft-0.986 sec., 330ft-2.756, 660ft-4.229/166.87 mph, 1,000ft-5.502. Left Lane: V. Gaines Runs 6.727/209.52, Now #14; Best prior run: 6.621/209.46, Was #13 Right Lane: Vincent Nobile Runs 6.600/209.49, Now #8; Best prior run: 6.624/209.65, Was #14 Gaines spun the tires right off the starting line...Nobile gets in the show. V. Gaines' incremental times: 60ft-1.079 sec., 330ft-2.896, 660ft-4.377/166.07 mph, 1,000ft-5.652. Vincent Nobile's incremental times: 60ft-0.975 sec., 330ft-2.762, 660ft-4.246/165.76 mph, 1,000ft-5.524. Left Lane: Erica Enders Runs 6.555/209.82, Now #2; Best prior run: 6.617/208.75, Was #12 Right Lane: Allen Johnson Runs 6.547/210.50, Now #1; Best prior run: 6.576/210.31, Was #1 This was a great side-by-side drag race to wrap up day one of Pro Stock qualifying. Enders goes to the number two spot. Erica Enders' incremental times: 60ft-0.971 sec., 330ft-2.737, 660ft-4.212/166.89 mph, 1,000ft-5.483. Johnson improves on his number one spot and is just a few ticks shy of the track E.T. record. Allen Johnson's incremental times: 60ft-0.973 sec., 330ft-2.734, 660ft-4.205/167.34 mph, 1,000ft-5.476. Timing data courtesy of CompuLink http://www.dragracecentral.com/image...t_endstory.gif From DragRaceCentral.com |
Round 3 Qualifying
Sat, 30 Jul 2011, 02:54 PM
http://www.dragracecentral.com/image...00_leftdot.gif Pro Stock Qualifying Notes, Session #3 By Rick Green http://www.dragracecentral.com/image...00_leftdot.gif http://www.dragracecentral.com/images/small_print.gif SONOMA, Calif. - Notes from round 3 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 24th annual FRAM-Autolite NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run: Left Lane: Gordie Rivera Runs 6.969/201.67, Now #14; No Prior Run Right Lane: Jason Line Runs 6.697/209.04, Now #13; No Prior Run Weather conditions: air temperature 70 degrees, relative humidity 59 percent, barometer 29.95 inches, adjusted altitude 1,290 feet, track temperature 94 degrees. Line gets down the track and number on the board, but won't be happy with this run. Rivera gets a number on the board. Left Lane: Ron Krisher Runs 6.597/210.01, Now #9; Best prior run: 6.608/209.62, Was #11 Right Lane: V. Gaines Runs 11.090/98.85, Now #15; No Prior Run Gaines with problems a soon as he lets out the clutch and pushes it back in. Krisher with a great pass. Ron Krisher's incremental times: 60ft-0.992 sec., 330ft-2.772, 660ft-4.249/166.54 mph, 1,000ft-5.523. Left Lane: Kurt Johnson Runs 6.576/209.98, Now #3; Best prior run: 6.607/209.39, Was #11 Right Lane: Shane Gray Runs 6.610/208.97, Now #13; No Prior Run Johnson with a great pass to move all the way up to the number three spot. Kurt Johnson's incremental times: 60ft-0.983 sec., 330ft-2.752, 660ft-4.228/166.56 mph, 1,000ft-5.502. Gray with his quickest pass of the weekend, but will stay in the number 13 spot. Shane Gray's incremental times: 60ft-0.989 sec., 330ft-2.767, 660ft-4.250/165.74 mph, 1,000ft-5.530. Left Lane: Vincent Nobile Runs 6.580/209.98, Now #6; Best prior run: 6.600/209.49, Was #11 Right Lane: Warren Johnson Runs 6.583/209.62, Now #7; Best prior run: 6.609/208.46, Was #12 These two were side-by side all the way down the quarter mile. Vincent Nobile's incremental times: 60ft-0.973 sec., 330ft-2.747, 660ft-4.227/166.29 mph, 1,000ft-5.504. Warren Johnson's incremental times: 60ft-0.972 sec., 330ft-2.748, 660ft-4.229/166.17 mph, 1,000ft-5.507. Left Lane: Rodger Brogdon Runs 6.600/209.30, Now #11; Best prior run: 6.595/209.14, Was #11 Right Lane: Greg Stanfield Runs 6.566/209.49, Now #3; Best prior run: 6.593/208.39, Was #10 Stanfield launched hard and keep it hooked up to run the quickest pass of the round, so far. Greg Stanfield's incremental times: 60ft-0.976 sec., 330ft-2.741, 660ft-4.215/167.14 mph, 1,000ft-5.489. Brogdon is just a tick off his qualified time from yesterday. Rodger Brogdon's incremental times: 60ft-0.988 sec., 330ft-2.766, 660ft-4.247/166.33 mph, 1,000ft-5.523. Left Lane: Mike Edwards Runs 6.569/210.05, Now #5; Best prior run: 6.587/209.56, Was #9 Right Lane: Greg Anderson Runs 6.551/209.69, Now #2; Best prior run: 6.592/209.69, Was #10 Edwards with his quickest pass of the weekend and the third quickest of the round. He moves into the top half of the show. Mike Edwards' incremental times: 60ft-0.978 sec., 330ft-2.752, 660ft-4.225/166.95 mph, 1,000ft-5.497. Anderson with his quickest pass of the weekend and the quickest of the round to go to the number two spot. Greg Anderson's incremental times: 60ft-0.973 sec., 330ft-2.735, 660ft-4.205/167.24 mph, 1,000ft-5.477. Left Lane: Ronnie Humphrey Runs 6.569/209.17, Now #6; Best prior run: 6.577/209.65, Was #8 Right Lane: Larry Morgan Runs 6.598/209.52, Now #8; Best prior run: 6.576/209.36, Was #7 Humphrey ties Edwards, but will give up the spot based on Edwards having the faster of the two runs. Ronnie Humphrey's incremental times: 60ft-0.978 sec., 330ft-2.743, 660ft-4.217/166.95 mph, 1,000ft-5.491. Morgan with another good pass, but gets bumped back one spot. Larry Morgan's incremental times: 60ft-0.997 sec., 330ft-2.770, 660ft-4.246/166.70 mph, 1,000ft-5.521. Left Lane: Allen Johnson Runs 6.538/211.56, Now #1; Best prior run: 6.547/210.50, Was #1 Right Lane: Erica Enders Runs 6.563/210.44, Now #3; Best prior run: 6.555/209.82, Was #3 Enders with another good pass, but will not improve. Erica Enders' incremental times: 60ft-0.977 sec., 330ft-2.746, 660ft-4.219/167.20 mph, 1,000ft-5.490. Johnson with the quickest pass of the weekend and has the quickest pass every round so far. Allen Johnson's incremental times: 60ft-0.969 sec., 330ft-2.732, 660ft-4.202/167.51 mph, 1,000ft-5.470. Timing data courtesy of CompuLink http://www.dragracecentral.com/image...t_endstory.gif From DragRaceCentral.com http://www.dragracecentral.com/image...00_leftdot.gif |
Final Qualifying
Sat, 30 Jul 2011, 05:36 PM
http://www.dragracecentral.com/image...00_leftdot.gif Pro Stock Qualifying Notes, Final Session By Rick Green http://www.dragracecentral.com/image...00_leftdot.gif http://www.dragracecentral.com/images/small_print.gif SONOMA, Calif. - Notes from final, round 4 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 24th annual FRAM-Autolite NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run: Left Lane: V. Gaines Runs 11.487/88.27, Now #16; Best prior run: 11.090/98.85, Was #16 Right Lane: Gordie Rivera Runs 15.702/50.81, Now #15; Best prior run: 6.969/201.67, Was #15 Both cars shook hard as soon as they let the clutch out and Rivera pushed the clutch back in and coasted on through the quarter mile. Gaines pushed in the clutch but then drove it on down the track. Rivera will qualify for a race for the first time since Sonoma 2000, but he has raced a limited schedule in those 11 years, only attending 46 races. Left Lane: Jason Line Runs 6.577/210.05, Now #9; Best prior run: 6.697/209.04, Was #14 Right Lane: Ron Krisher Runs 14.815/54.90, Now #13; Best prior run: 6.597/210.01, Was #12 Krisher shook right off the line and clicked it off. Line with his quickest pass of the weekend to move up the ladder...Jason Line's incremental times: 60ft-0.990 sec., 330ft-2.759, 660ft-4.232/166.93 mph, 1,000ft-5.504. Left Lane: Shane Gray Runs 6.674/208.39, Now #14; Best prior run: 6.610/208.97, Was #14 Right Lane: Rodger Brogdon Runs 6.580/210.24, Now #10; Best prior run: 6.595/209.14, Was #12 No help here for Gray and he will stay in the number 14 spot. Brogdon with his quickest pass of the weekend and the second quickest pass of the session. Rodger Brogdon's incremental times: 60ft-0.994 sec., 330ft-2.762, 660ft-4.235/166.99 mph, 1,000ft-5.507. Left Lane: Warren Johnson Runs 6.638/208.17, Now #12; Best prior run: 6.583/209.62, Was #12 Right Lane: Vincent Nobile Runs 6.600/209.36, Now #11; Best prior run: 6.580/209.98, Was #11 Weather conditions: air temperature 74 degrees, relative humidity 54 percent, barometer 29.92 inches, adjusted altitude 1,630 feet, track temperature 116 degrees. A couple good passes, but neither driver improves. Warren Johnson's incremental times: 60ft-0.986 sec., 330ft-2.779, 660ft-4.271/165.15 mph, 1,000ft-5.556. Vincent Nobile's incremental times: 60ft-0.987 sec., 330ft-2.760, 660ft-4.243/165.92 mph, 1,000ft-5.522. Left Lane: Larry Morgan Runs 13.022/64.28, Now #8; Best prior run: 6.576/209.36, Was #8 Right Lane: Kurt Johnson Runs 6.597/209.07, Now #7; Best prior run: 6.576/209.98, Was #7 Morgan with problems right off the starting line and he clicked it off. Johnson with another good pas, he will not improve and will start from the top half of the show. Kurt Johnson's incremental times: 60ft-0.981 sec., 330ft-2.757, 660ft-4.240/165.86 mph, 1,000ft-5.519. Left Lane: Greg Stanfield Runs 6.604/208.68, Now #4; Best prior run: 6.566/209.49, Was #4 Right Lane: Ronnie Humphrey Runs 6.571/209.95, Now #6; Best prior run: 6.569/209.17, Was #6 No help here for Stanfield, but still a good pass. Humphrey with another good pass, but doesn't improve. He will start from the top half of the show tomorrow. Ronnie Humphrey's incremental times: 60ft-0.982 sec., 330ft-2.751, 660ft-4.224/167.01 mph, 1,000ft-5.497. Humphrey with the quickest pass of the session. Left Lane: Erica Enders Runs 6.588/209.46, Now #3; Best prior run: 6.555/209.82, Was #3 Right Lane: Mike Edwards Runs 6.579/209.59, Now #5; Best prior run: 6.569/210.05, Was #5 Neither driver will improve, but Edwards with the third quickest pass of the round. Mike Edwards' incremental times: 60ft-0.979 sec., 330ft-2.756, 660ft-4.231/166.99 mph, 1,000ft-5.505. Enders with the fifth quickest pass of the session. Erica Enders' incremental times: 60ft-0.985 sec., 330ft-2.758, 660ft-4.236/166.54 mph, 1,000ft-5.512. Left Lane: Greg Anderson Runs 6.566/210.31, Now #2; Best prior run: 6.551/209.69, Was #2 Right Lane: Allen Johnson Runs 6.582/210.21, Now #1; Best prior run: 6.538/211.56, Was #1 Anderson with a great pass to wrap up qualifying with the quickest of the round. Greg Anderson's incremental times: 60ft-0.977 sec., 330ft-2.747, 660ft-4.221/166.72 mph, 1,000ft-5.493. Johnson holds on to the number one spot for the third time this season and 18th time in his career. Johnson with the sixth quickest pass of the round. Allen Johnson's incremental times: 60ft-0.982 sec., 330ft-2.759, 660ft-4.235/166.70 mph, 1,000ft-5.508. Timing data courtesy of CompuLink http://www.dragracecentral.com/image...t_endstory.gif From DragRaceCentral.com |
Final Qualifying Order
Sat, 30 Jul 2011, 05:46 PM
http://www.dragracecentral.com/image...00_leftdot.gif Pro Stock Qualifying, Final Order http://www.dragracecentral.com/images/small_print.gif SONOMA, Calif. - Final order after 4 rounds of qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 24th annual FRAM-Autolite NHRA Nationals: Psn---Num-Driver, Home Town, Car Type---------------Qual-ET--Qual-Spd-Top Spd 1 6 Allen Johnson, Greeneville TN, '11 Avenger 6.538@ 211.56& 211.56 2 1 Greg Anderson, Mooresville NC, '09 GXP 6.551 209.69 210.31 3 48 Erica Enders, New Orleans LA, '10 Cobalt 6.555 209.82 210.44 4 2 Greg Stanfield, Bossier City LA, '09 GXP 6.566 209.49 209.49 5 3 Mike Edwards, Coweta OK, '09 GXP 6.569 210.05 210.05 6 2062 Ronnie Humphrey, Jacksonville NC, '09 GXP 6.569 209.17 209.95 7 21 Kurt Johnson, Sugar Hill GA, '09 GXP 6.576 209.98 209.98 8 357 Larry Morgan, Newark OH, '11 Mustang 6.576 209.36 209.52 9 5 Jason Line, Mooresville NC, '09 GXP 6.577 210.05 210.05 10 9 Rodger Brogdon, Tomball TX, '09 GXP 6.580 210.24 210.24 11 154 Vincent Nobile, Dix Hills NY, '11 Avenger 6.580 209.98 209.98 12 208 Warren Johnson, Sugar Hill GA, '09 GXP 6.583 209.62 209.62 13 8 Ron Krisher, Warren OH, '09 GXP 6.597 210.01 210.01 14 4 Shane Gray, Denver NC, '09 GXP 6.610 208.97 208.97 15 752 Gordie Rivera, Yuma AZ, '09 GXP 6.969 201.67 204.79 16 55 V. Gaines, Lakewood CO, '11 Avenger 11.090 98.85 209.52 @ = Track ET Record & = Track Speed Record Timing data courtesy of CompuLink http://www.dragracecentral.com/image...t_endstory.gif From DragRaceCentral.com |
Round 1 Eliminations
Results for Elimination Round 1
SONOMA, Calif. - SUMMIT FastNews - Results of round 1 eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 24th annual FRAM-Autolite NHRA Nationals: W/L Driver R-Time E-Time Speed (W) Jason Line (Summit Racing Equipment GXP) 0.041 6.573 210.37 (L) Larry Morgan (Lucas Oil/Summit Mustang) 0.050 6.618 209.79 Weather conditions: air temperature 67 degrees, relative humidity 62 percent, barometer 29.93 inches, adjusted altitude 1,141 feet, track temperature 104 degrees.Line is 14 - 7 against Morgan in prior events. Line with a a slight starting line advantage and then runs his quickest pass of the weekend for the win. Jason Line's incremental times: 60ft-0.982 sec., 330ft-2.758, 660ft-4.231/166.91 mph, 1,000ft-5.501. Morgan slowed from his qualifying time. (W) Rodger Brogdon (The Edge GXP) 0.027 6.568 210.31 (L) Kurt Johnson (Pietroj #1 GXP) 0.028 6.569 210.21 Brogdon is 2 - 1 against Johnson in prior events. Brogdon is just a tick of an advantage on the starting line and then Johnson has the lead until half track where Brogdon takes the lead and wins a very close race. Rodger Brogdon's MOV: 0.0021 seconds (approximately 8 inches). Brogdon with his quickest pass of the weekend. Rodger Brogdon's incremental times: 60ft-0.988 sec., 330ft-2.755, 660ft-4.227/167.28 mph, 1,000ft-5.497. Johnson with his quickest pass of the weekend in the losing effort. Kurt Johnson's incremental times: 60ft-0.986 sec., 330ft-2.753, 660ft-4.227/166.83 mph, 1,000ft-5.498. (W) Mike Edwards (Penhall/K&N/Interstae GXP) 0.014 6.563 210.67 (L) Warren Johnson (K&N Filters GXP) 0.121 6.591 209.92 Edwards is 25 - 16 against Johnson in prior events. Edwards with the starting line advantage and then runs his quickest pass of the weekend for the win. Mike Edwards' incremental times: 60ft-0.980 sec., 330ft-2.749, 660ft-4.222/167.22 mph, 1,000ft-5.493. (W) Greg Stanfield (Nitrofish GXP) 0.044 6.587 209.56 (L) Ron Krisher (Valvoline GXP) 0.081 6.619 206.67 Stanfield is 10 - 3 against Krisher in prior events. Stanfield with the starting line advantage and never trailed for the win. Stanfield will give up lane choice to Edwards in the next round. (W) Erica Enders (ZaZa Energy Cobalt) 0.024 6.568 210.24 (L) Shane Gray (Service Central GXP) -0.012(R) 6.582 209.07 Enders and Gray have each won 1 times against the other in prior events. Gray is too quick on the tree and turns on the red light giving Enders the freebie. (W) Allen Johnson (Mopar/J & J Racing Avenger) 0.020 6.563 210.50 (L) V. Gaines (Kendall Oil Avenger) 0.044 6.882 165.03 Johnson is 11 - 6 against Gaines in prior events. Johnson with the starting line advantage and never trailed for the win. He will tie Edwards for the low E.T. of the round. Edwards will have lane choice Line in the next round. (W) Greg Anderson (Summit Racing Equipment GXP) 0.093 6.546 210.93 (L) Gordie Rivera (Gordies Speed Center GXP) 0.108 7.800 131.39 This is the first time Anderson and Rivera have faced each other in eliminations. Anderson is out of the gate first and never trailed with the quickest pass of the round. Greg Anderson's incremental times: 60ft-0.982 sec., 330ft-2.745, 660ft-4.212/167.74 mph, 1,000ft-5.478. Anderson will have lane choice over Brogdon in next round. (W) Vincent Nobile (Mountainview Tire Avenger) 0.046 6.581 210.24 (L) Ronnie Humphrey (Genuine Hot Rod Hardware G 0.072 6.608 209.36 Nobile is 3 - 0 against Humphrey in prior events. Nobile with the starting line advantage and never trailed for the win. Nobile will give up lane choice to Enders in the next round. From NHRA.Com |
Summary of Eliminations
Sun, 31 Jul 2011, 09:30 PM
http://www.dragracecentral.com/image...00_leftdot.gif Summary of Eliminations in Pro Stock http://www.dragracecentral.com/images/small_print.gif SONOMA, Calif. - Summary of eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 24th annual FRAM-Autolite NHRA Nationals: Round 1: Jason Line, Mooresville NC, '09 GXP, Left lane, (0.041) 6.573 210.37 def. Larry Morgan, Newark OH,'11 Mustang, (0.050) 6.618 209.79 Rodger Brogdon, Tomball TX, '09 GXP, Left lane, (0.027) 6.568 210.31 def. Kurt Johnson, Sugar HillGA, '09 GXP, (0.028) 6.569 210.21 Mike Edwards, Coweta OK, '09 GXP, Left lane, (0.014) 6.563 210.67 def. Warren Johnson, Sugar HillGA, '09 GXP, (0.121) 6.591 209.92 Greg Stanfield, Bossier City LA, '09 GXP, Left lane, (0.044) 6.587 209.56 def. Ron Krisher, WarrenOH, '09 GXP, (0.081) 6.619 206.67 Erica Enders, New Orleans LA, '10 Cobalt, Left lane, (0.024) 6.568 210.24 def. Shane Gray, DenverNC, '09 GXP, (-0.012 foul) 6.582 209.07 Allen Johnson, Greeneville TN, '11 Avenger, Left lane, (0.020) 6.563 210.50 def. V. Gaines,Lakewood CO, '11 Avenger, (0.044) 6.882 165.03 Greg Anderson, Mooresville NC, '09 GXP, Left lane, (0.093) 6.546 210.93 def. Gordie Rivera, YumaAZ, '09 GXP, (0.108) 7.800 131.39 Vincent Nobile, Dix Hills NY, '11 Avenger, Right lane, (0.046) 6.581 210.24 def. Ronnie Humphrey,Jacksonville NC, '09 GXP, (0.072) 6.608 209.36 Round 2: E Enders, Left lane, (0.050) 6.568 210.47 def. V Nobile, (0.028) 6.618 210.14 J Line, Right lane, (0.023) 6.564 210.34 def. A Johnson, (0.018) 6.569 210.73 M Edwards, Left lane, (0.011) 6.561 210.60 def. G Stanfield, (0.033) 6.589 209.43 G Anderson, Right lane, (0.082) 6.564 210.34 def. R Brogdon, (0.069) 6.597 209.46 Round 3: G Anderson, Left lane, (0.036) 6.567 209.92 def. E Enders, (0.027) 16.171 49.55 M Edwards, Left lane, (0.018) 6.588 209.72 def. J Line, (0.035) 6.577 210.28 Round 4: G Anderson, Left lane, (0.043) 6.562 210.28 def. M Edwards, (0.031) 6.576 210.14 Low ET: Allen Johnson 6.538 seconds Top Speed: Allen Johnson 211.56 MPH Timing data courtesy of CompuLink http://www.dragracecentral.com/image...t_endstory.gif From DragRAceCentral.com |
