This doesn't look right to me:
Old Jan 26, 2012 | 03:28 PM
Slice's Avatar
Trying to reassemble this after a year. Doesn't look right to me. Does the cut end of the adjustment nut sit up against the washer like this????????
Attached Thumbnails This doesn't look right to me:-z-bar-linkage-002.jpg
Old Jan 26, 2012 | 03:56 PM
Nope I would flip it around. I see you have a book, the book doesn't help?
Old Jan 26, 2012 | 04:36 PM
Slice's Avatar
The book has it the way I do but it's hard to tell how it sits against the washer. Maybe I'm overthinking it, but I just don't get the funcion of that nut. It seems to spin freely like a regular nut. So why the cuts??
Attached Thumbnails This doesn't look right to me:-z-bar-linkage.jpg
Old Jan 26, 2012 | 04:41 PM
Slice's Avatar
Love the Aspen by the way.
Old Jan 26, 2012 | 04:50 PM
Thanks, I have the same looking rod on it since it's a 4 speed. I will refresh my memory tonight. I just think I flipped mine over because I thought the fatter part of the nut should be up against the washer.
Old Jan 26, 2012 | 04:55 PM
Slice's Avatar
Thanks
Old Jan 26, 2012 | 07:34 PM
Thanks
I did mine just like yours is and just like it shows in your book. I got the flashlight out and checked.
Old Jan 27, 2012 | 07:31 AM
Slice's Avatar
Thanks. I Put it together like that. I think that nut is designed so you can squeeze the tab that lines up with the groove on the rod. At least that's what I did and it seemed to lock the nut in place.
One thing that did surprise me was that I installed a new clutch (even though the old one was hardly used) but had to adjust the nut way back to take the slack out of the pedal. I was expecting the opposite.
Could it be just a different combo of clutch and throw-out bearing just sets up in a different position?
Ramahan
Feb 5, 2011 05:43 AM
Tehone
Jan 8, 2010 07:29 AM
05ramjsp
Apr 19, 2009 03:45 AM
Evnas
Apr 12, 2009 06:13 PM
siliconcrunch
Dec 1, 2008 10:57 AM
